Tosh 36zp18p
Discussion in 'General TV Discussions Forum' started by steve k, Nov 4, 2001.
  1. steve k
    steve k
    Apr 15, 2001
    703
    Birmingham
    +53
    Thinking of getting one of these puppy's am i doing the right thing.?
    Only the problems that are posted on the forums are makin me think am i makin the right desision.
    Any suggestions welcome.
  2. dts borg
    dts borg
    Sep 5, 2001
    579
    Hornchurch
    +8
    Don't let the posts on this board change your mind, as all large widescreen sets have something that you can find fault with..
    Electro centre are selling this set for £1480.00 A great price for a set this size.
    ..................MAKE IT SO :rolleyes:
  3. the_saints
    the_saints
    I guess it really depends on how much the faults "bug" you. Especially when considering that this has an RRP of £2K I feel that the faults are too annoying. The staining issue is too noticeable and I would say because of this my old TV was much better.
    Saying that looking at looking at alternatives the Sony completely failed the demonstration due to geometry errors and a green stain. However, the Panasonic seemed to be OK. I then checked it at a Panasonic shop where again all seemed OK. So fingers crossed!
    If you are getting one I suggest you get from a good retailer - one who will not try to wriggle out of any problems and will help get the best set for you
  4. Spencem
    Spencem
    Oct 15, 2001
    197
    Northampton
    +9
    :D I paid the full £2k for mine and think it is worth every penny. Yes I can see dark bars when I'm looking at my DVD input and the DVD is off, but never at any other times. I would agree though to get it from a decent retailer just in case some of the other things you will have read about happen.
    The only other problem I had was that the set showed up issues with my buget sources and so lead to a round of upgrades ;)
    Good luck.
