Tosh 36ZP18P Sound vibration
Discussion in 'General TV Discussions Forum' started by 306GTI6, May 15, 2002.
  1. 306GTI6
    306GTI6
    Anyone had a problem in that the casing of the Toshiba 36ZP18P seems to resonate/vibration on normal speech?
    It is getting very much on my nerves, I don't want the hassle of getting engineer out or shipping it back if it is something simple.
    TIA,
    Andy.:p
  2. Doubledoom
    Doubledoom
    You have to have the hassle of getting someone out i'm afraid.
  3. 306GTI6
    306GTI6
    Any idea what the problem is? I moved the whole set including stand away from the wall this morning and checked all the case screws were tight. I don't notice it in the 15 minutes or so before coming to work. Is it internal problem like something loose?
    Andy.
  4. Doubledoom
    Doubledoom
    The sub has been known to come loose and rattle against the case. In fact this has been a trait on Toshiba models going back some time.
  5. 306GTI6
    306GTI6
    Is it easy to whip the back off and tighten up yourself?
  6. Doubledoom
    Doubledoom
    I wouldn't try it. If the warrenty seal is broken and you then do a call out, they could spot the break and decide not to fix it free of charge.
  7. 306GTI6
    306GTI6
    OK. I'll see how it goes since I tightened things this morning. I didn't know they had a security seal.
    Is it on the inside as I didn't see anything on the outside. I just can't be without it whilst the World Cup is on!!
    Andy.
