Quantcast
Tosh 36ZP18P help please
P
perry ferrit
I have just conneceted a pioneer dvd player up to my tosh via the component in sockets but the only problem is for some reson i cannot change the colour system on the setup menu. Every time i go to the setup menu while i am on av4 the setup menu is greyed out but while i am on av1 2 and 3 i can got straight onto the setup menu and change the colour system from pal to ntsc etc. I would be very greatful if some kind person could check there 36zp18p to see if there set was the same.
Thanks alot.......:confused:
S
stranger
in the tosh' setup menu select auto-pal ntsc and the t.v. will select automaticaly.
