Tosh 36zp18 channel 5
Discussion in 'General TV Discussions Forum' started by swainstong, Feb 19, 2002.
  1. swainstong
    swainstong
    had my 36zp18 for 5 months now and suddenly lost chan 5 reception. i have checked settings and they seem ok, am i missing something silly. i have it set on 35 and even fine tuning makes no difference. i also have dark vertical lines on both edges of screen especially noticable watching football. got a comet engineer coming on thursday any info appreciated.:rolleyes:
  2. m@rk
    [email protected]
    Jan 3, 2002
    1,222
    83
    Lincolnshire
    +374
    Are you able to tune into Channel 5 on a different program?
    If no then it's a transmission problem. If yes then it looks like a fault.
    As far as the dark bars go, look at the 2 large 36ZP18P threads further down. You will find that these are not faults but features of the set.
  3. swainstong
    swainstong
    not sure i understand the question regarding different program.
    but i can receive chan 5 on a seperate tv connected to same aerial, i can as expected still receive thru sky digital. i realise that the freq is very close to the video output and i am not experiencing any problems with video. thanks for the info going to check further posts again
  4. m@rk
    [email protected]
    Jan 3, 2002
    1,222
    83
    Lincolnshire
    +374
    What I meant was:
    Normally, you have BBC1 on Programme 1, BBC2 on 2, ITV on 3, Ch4 on 4 and Ch5 on 5.
    Can you tune in say programme 6 to Channel 5? This would then help discover where the fault lies.
    If you can get Ch5 on a different programme button, then it would appear to be a fault with programme 5 whereas if you can't get Ch5 at all (Sky excluded), then I would look towards a transmission fault.
  5. swainstong
    swainstong
    thanks for quick response, far better than service dept.
    i just checked tuning on a different chan (9) and still no reception when i tune to 35 just a blue screen flickering, as i say i can receive on portable tv at same coax.
    regards
  6. Spencem
    Spencem
    Oct 15, 2001
    202
    Northampton
    +9
    Have you tried disconecting your VCR? It could be a problem with the VCR causing cross channel interferance. Also have you tried scanning accross the entire spectrum rather than just UHF 35?
    Otherwise it's down to the Commet engineer, lets hope he recognises it as a TV and not a large microwave :devil:
  7. Monster
    Monster
    Oct 9, 2000
    978
    Adelaide
    +30
    Have you tried using the VCR tuner?
