Tosh 36ZP Speakers
DavidCook
Joined
Feb 20, 2002
Messages
95
Reaction score
2
Points
39
Age
68
Location
South Normanton Derbyshire
Apologies if this has been covered before but! What is the relationship between the speaker controls and the TV's volume control? ie Each speaker has a range from 0-100 and it appears to make little difference where I select as I can control the volume from 'the volume control!!'
Should I have high speaker values and low volume or vice versa or doesn't it matter?
Is there an optimum setting?
If you are using the external speakers, the various options allow you to control the volumes of the speakkers......eg, make the rear right louder if it's further from your listening position than the rear left. You can also make the rears louder or softer etc. It's really just to allow you to set up the sound the way it suits you
Brian
StormAudio ISR Fusion 20 AV Receiver - review coming soon #HomeCinema #Amplifier #VideoShort
Back
