Tosh 36ZP Setup
Discussion in 'General TV Discussions Forum' started by [email protected], Feb 2, 2002.
  1. m@rk
    [email protected]
    Jan 3, 2002
    1,222
    83
    Lincolnshire
    +374
    I am sure some of these questions were answered in the monster tosh thread last month but I can't find them.
    On the above TV, there are 3 picture settings (1,2 and 3). The manual tells you sod all about what they do but I seem to remember that one of them cuts out all the processing and results in a cleaner picture.
    Does anybody know?
    It's all well and good replacing a set but it took me 3 weeks to get the last one set up correctly and now I have to start all over again :(
  2. cliff007
    cliff007
    You should set it to Picture Mode 3. It switches off the dynamic contrast.
  3. Markster
    Markster
    Cliff007 - Was it you who recently posted about scrolling bars on the sony KV36"? - Did you resolve this?.
    I thought this only affected the Fq models
  4. cliff007
    cliff007
    Markster - yes, I did post about the scrolling bars. I can confirm it is present on the 36FS70, I know of two other people's sets that have the same problem.
  5. Guest
    Some information I got from Toshiba a while ago:
    Picture mode 3 has Horizontal Scan Velocity Modulation (HSVM) turned off.
    This is used to sharpen up the edges of fast black to white & white to
    black transitions ie: text in captions (not Teletext) without it the right
    hand edges of bright objects look softer.
    Picture mode 1 is for Shop demonstration only ie: 100% contrast, 100% HSVM,
    50% Brightness, Colour and Sharpness.
    Picture mode 2 at mid settings 50% inc (HSVM) is the best starting point
    for use at home.
    Picture mode M is what is memorised after you have tweaked either of the
    other modes for personal taste.
    There are two modes of 100Hz operation:-
    100Hz = this is the original method of doubling frame scan (called AA+BB)
    it overcomes frame flicker but cannot improve line jitter (interlace is
    causing this) hence the fact when an On screen menu is displayed it is
    bouncing between the lines.
    Natural = the latest of our designs using AA'+BB' system, A' and B' are
    fields made up from the previous fields in memory but with and fast moving
    objects ignored.
    Note: UK 625 line TV display is made up of 25 pictures per second (called a
    frame), each picture is made from an Odd number field, lines 1,3,5,7,9 etc
    then an Even field, lines 2,4,6,8 etc hence a normal vertical scan rate of
    50Hz.
  6. m@rk
    [email protected]
    Jan 3, 2002
    1,222
    83
    Lincolnshire
    +374
    Thanks Den:
    Thats exactly what I needed to know.
    Where did you get this info from though?
  7. Guest
    I got it from the Toshiba technical support department when my saga with TV problems began. I don't know why they don't print this kind of information in the manual.
