Tosh 36ZP Brightness Problem "THE FIX"
Discussion in 'General TV Discussions Forum' started by sirees01, Sep 26, 2001.
  1. sirees01
    sirees01
    O.K Engineer just popped round to sort out the fix for the brightness problem.
    The Paramaters to change are as follows:<br />BS2<br />2BS2<br />3BS2<br />WBS2<br />NBS2
    The values on all these paramaters need to change to 07H
    Example: My Old values were:<br />BS2 = 09H<br />2BS2= 00H<br />3BS2= C4H<br />WBS2= 09H<br />NBS2= 09H
    I hope this helps anyone who is suffering the same problem <br /> <img src="wink.gif" border="0">
  2. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    Thanks, Simon.
    I'll try applying the new values tonight.
    Did you find that they improved your picture?
    Nigel.
  3. sirees01
    sirees01
    Too early to tell yet, Eastenders is the best program to judge it on.It always plays up with Eastenders, I will post with my verdict a.s.a.p <img src="smile.gif" border="0">
  4. sirees01
    sirees01
    Balders,<br />The fix has definately worked, Eastenders showed no brightness fluctuation at all. <img src="smile.gif" border="0"> <br />Did you manage to do the fix yourself ?
  5. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    I'm glad to hear that the fix sorted out your picture.
    I eventually managed to apply the fix (it took some time to work out how to actually do anything in the Designer Menu). The picture does seem to look a little better, but it hasn't really improved the problem that I was trying to cure.
    The problem I've got is that bright areas can sometimes be too bright, eg a white shirt on a sunny day, or a white wall with the sun reflecting off of it. It's not a problem most of the time, I just notice it sometimes, and its always on whites. I wonder whether it's anything to do with the set being new, and the screen needing to 'burn in' a bit.
    Nigel.
  6. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    846
    19
    leeds UK
    +16
    My old set had the symptons you describe, although mayby a little worse such as sunlit grass being nearly white. New set came today and is much better although still slightly bright on whites. No sign of this bightness fluctuation thjough, are new sets set with the above changed parameters now?<br />However if you think it is faulty get the engineer to condemm it and get a new one.
  7. Doubledoom
    Doubledoom
    balders, have you tried turning the dynamic contrast off?
    If you amend picture setting 1 or 2, you get DC on. If you amend picture setting 3, DC is off.
    It may help
  8. sc00by
    sc00by
    Folks,<br /> Can anyone post how to access these menus.<br />Just got my 32ZP18P and it's fantastic but just in case...
    Ta
    Dave
  9. Doubledoom
    Doubledoom
    Press mute and release<br />Press mute and keep it pressed down.<br />Press menu (on front of tv)
    That enters the "S" service menu.
    To enter the "D" designer menu, you go into the service menu and then press and hold down CALL on the remote and then press menu on the front of the tv
    Other information on the Toshiba service/designer menus can be found <a href="http://groups.google.com/groups?as_q=toshiba%20designer%20menu" target="_blank">here</a>
  10. sc00by
    sc00by
    Thanks for that.
    Dave
  11. Guest
    Hi all,
    Just wondering if I go into the S menu to fix brightness, how do you move about the menu to change different settings? Also how do you exit S menu?
    Many thanks.
  12. Doubledoom
    Doubledoom
    Channel up/down to change the setting. Volume up/down to change the value.
    Turn the tv off and then back on again to get out of the menu
  13. the_saints
    the_saints
    Has anyone managed to get the staining/feint vertical bars corrected by an engineer?
  14. Guest
    Hi all!
    Please, please someone help me! I went into the Service menu of the above TV and changed some settings by mistake! Could some kind soul please do me a favour and just tell me their default settings for the below er, settings. I've still got a picture but I'm afraid I may have changed some settings below which I shouldn't have. Sorry if this mail does'nt make sense.
    sy2n
    sysx
    sysn
    rcut
    gcut
    bcut
    gdrv
    bdrv
    cntx
    brtc
    Someone please help. I promise never to go never a service menu again!
    :eek:
  15. Pedro
    Pedro
    Hi all!
    sy2n Not listed
    sysx Not listed
    sysn Not listed
    rcut 0410h / 54h / 01010100b
    gcut 0411h / 65h / 01100101b
    bcut 0412h / 5ch / 01011100b
    gdrv 0413h / 34h / 00110100b
    bdrv 0414h / 2dh / 00101101b
    cntx 0415h / 7fh / 01111111b
    brtc 0416h / 7eh / 01111110b
    Hope that helps .......
    The settings on my Toshiba 32wt98b TV are
    listed for you.Please be aware that my TV is a 50hz model.
    Don't forget write down all the original settings BEFORE going into the service menu !
    Good luck anyway.
    Regards
    Pete.
  16. Guest
    Hi Pedro,
    Thanks for posting your settings, but I'm afraid to try those as yours is a different set. Sirees, balders and doubledoom, please help :)!
    Thanks again Pedro
    Cheers,
  17. Captain Jack
    Captain Jack
    Apr 20, 2003
    82
    +3
    Just done it on mine... worked a treat :)
