tosh 36zd26p and on screen logos
Discussion in 'General TV Discussions Forum' started by dan74, Jan 18, 2003.
  1. dan74
    dan74
    i bought a toshiba 36zd26p from robertsons,set it up and i am getting funny effects with on screen logos there are strange moving lines moving through logos,i also get the same problem when i use my playstation 2, i also had the effect with my sky panasonic digibox but managed to get rid of effect by going into picture setup on sky digibox and turned on the scart control, can anyone tell me what is causing this,and can anyone tell me what is the best picture setup for this telly.thank you
  2. cerebros
    cerebros
    Dec 27, 2002
    1,294
    48
    Leicester
    +29
    the xxZD26's all have a problem with composite video. Just use S-video, RGB, or component inputs and the problem will go away
  3. dan74
    dan74
    i have my tv and sky digi box connected by a thor scart lead through the rgb socket,when i turn the scart control on in the digibox picture setup menu the funny effects on screen logos disappear, if i watch normal tv i still get the same effects on screen logos, i have my playstation 2 plugged into the second scart and get the same thing happen on static writing/boxes, i have tryed in the other scart sockets and on side panel but still got the same problem.i also get the same problem on dvds played through my limit9900se dvd player, for example when i play a dvd i get the effect on the film setup option the box with lines appears appears around the outside of the selected option,ie play,scence selection.any ideas what it could be.
