Tosh 36" Widescreen and SKY Remote control
Discussion in 'General TV Discussions Forum' started by aqureshi, Oct 19, 2001.
  1. aqureshi
    aqureshi
    I just had my 36ZP18 delivered and connected to my DVD,Digi box and VCR.My previous TV was Sony and Sky remote control used to work with that TV, but it does not work, i mean cannot control the sound and on/off with the Tosh TV. Is there a setting I need to do in order for the remote to work.
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    It tells you how to set the sky box up for different tv's in the manual that came with it.
  3. dts borg
    dts borg
    Sep 5, 2001
    578
    Hornchurch
    +8
    The codes in the digi box manuals don't always work.Call sky as they have all the new codes.It worked for me......
    .........MAKE IT SO :eek:
  4. aqureshi
    aqureshi
    Thanks Ken for your help!Much appreciated.
    cheers
