tosh 36+DD
Discussion in 'General TV Discussions Forum' started by MiG, Dec 22, 2001.
  1. MiG
    MiG
    newbie be oh so gentle
    had tosh 36zp for a month (sorry tosee /hear about other 36zp owners havin major probs, havn't noticed any yet) connected pioneer 626d via component and optical leads but can only get dolby digital 2.0. wen 5.1 is selected all i get is silence ???
    can anyone with similar setup (or better savvy ) help:confused:
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    Does the 626 have component outputs, I sure mine didn't!
    Make sure the 626 is set to output AC3 / DD rather than PCM.
  3. MiG
    MiG
    thanx for postiin Nic Rhodes got the model no. wrong itsa pioneer 606d doh. has component out which works fine but can only get DD 2.2 not 5.1 when the pcm/dolby digital is selected in the player menu. any ideas if its the pioneer or tosh misbehaving.
  4. balders
    balders
    Jul 31, 2001
    451
    28
    +25
    Could be you're not getting a signal on the optical cable, or it's not set up at the TV end.
    Have you assigned the optical input to the AV input that you are using for your DVD player?
    If not, you'll need to go the the AV setup menu on your TV and set Digital Input 1 (or similar) to EXT3 (for component input). Hopefully, you should then get glorious DD 5.1.
    The only other thing I can think of is to make sure that the optical cable is firmly attached. I remember it took quite a firm push until the optical cable 'clicked' into my Tosh, so much so that I was a bit nervous that I'd break something!
    Good luck,
    Nigel
  5. MiG
    MiG
    there is definitly a signal as the tosh picks it up as DD 2.2
    and displays no signal wen dvd is switched off, has anyone else
    got a pioneer 606d and could maybe tell me wot settings they use
  6. Doubledoom
    Doubledoom
    Try a co-ax instead of a optical cable. This will eliminate the cable as the cause or answer your problem.
  7. simon1
    simon1
    Jul 7, 2001
    918
    28
    Teesside
    +58
    You must select 'bitstream' in the setup menu of your dvd player.
    If you have done this, then there is something else amiss.
