Tosh 330e help
barrykil
Bought this today supposed to be multi region but only region 2 any thing i can do about this or is it a return trip to Richer Sounds thanks
barrykil
thanks for that had a look, couldn`t sort it,decided to change only to be told all the tosh`s they`ve got hadent in fact been chipped so got a sharp dv-sloh straight swap,thanks anyway
Crustyloafer
The Toshibas don't need chipped at all, it's just a simple software upgrade which can be done in 5 minutes. You should get the Toshiba back as it's a much better player than the Sharp.
Podcast: LG C1 Review, Apple Lossless & Dolby Atmos @ no cost, Sennheiser IE900 review + more
