Tosh 32ZP48 wonky picture
Discussion in 'TVs' started by Philski, Mar 31, 2005.
  1. Philski
    Philski
    The quality of this TV is great. Picture and sound etc superb.
    I have one issue.
    When watching in Widscreen, the black lines at the top and bottom of the picture in opposite corners (Top left and bottom right) are about 5-7mm wider than the other two.
    This makes the picture look like it is tipping up slightly.
    I know it isnt a lot but now i have seen it, i cant stop looking at it.
    I know the 36" model has a geometric adjustment on it, but the 32" doesnt.Would this make a difference anyway?
    This is my second one already as the first had the same problem.
    Is there something i'm missing or am i being too critical of an otherwise great bit of kit ?
  2. fdxd
    fdxd
    5-7mm probbaly means you can get it replaced.
    I had my tv replaced 3 times. So dont fret :laugh:
