Tosh 32ZP48 Setup
Discussion in 'General TV Discussions Forum' started by StuartC, Nov 1, 2004.
  1. StuartC
    StuartC
    Oct 25, 2004
    4
    Finally getting my 32ZP48 tomorrow from Sound & Vision. Is there a recomended set up in terms of scarts & RGBS? I have a Sky + box & am getting a toshiba SD43 home cinema. Will there be recommendations in the Toshiba instructions. Will the TV come set up to the best quality/sound aswell??!!
    Thanks in advance
  2. Rushy
    Rushy
    Jun 26, 2002
    99
    11
    Manchester
    +16
    The TV is very poorly setup by default, look in the PZ48 review thread for other peoples setup (incuding mine).
    always use RGB cables and if any of your appliances support it use component instead as the progressive scane via DVD is amazing.
