Tosh 32ZP48 questions
Discussion in 'TVs' started by dpluxor, Jan 27, 2005.
  1. dpluxor
    dpluxor
    Jan 27, 2005
    64
    Hi all,
    I'm new to this group as I only just got me telly yesterday. So far very please but do have a couple of initial questions.
    My setup is this ...
    VCR-Out Scart on Sky Digital to EXT2 on Philips DVDR80 recorder
    TV-Out Scart on Sky Digital to EXT1 on TV
    Component Out of DVD Recorder to Component In on TV
    If I want to watch a DVD or watch something I recorded, I have to manually go to EXT4 on the TV to get to the Comp Video picture, I take it there is no short cut to this, before when I turned on the DVD it used to turn the TV over for me but I assume this is part of a scart cables control mechanism and is not possible through component. Also, when I got to EXT4 the picture is always 4:3 which is really annoying, can I stop the TV altering the aspect ratio when I go this connection ?
    If I then want to watch sky I used to be able to press TV & Sky on the remote and it would switch to EXT1 for me, it still does do this if I am watching a terrestrial channel on the TV but it wont do it if I am viewing EXT4, anyone know why ?
    Also, a question about the actual recorder (Philips DVDR80), if it is on standby and I turn it on, it always comes onto BBC1 regardless of what you were last on. We nearly always record from Sky on EXT2 so I would like it to switch on onto EXT2. If anyone has this recorder they will know what a pain it is to change the channel on it (pressing MONITOR button and all that rubbish)
    David
  2. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Hi, I can only give you some help with the ext 4 'problem' - as you have already summised it is component in and there is no method of 'signalling' the tv to switch to ext 4 - this is 'normal' for this model. I have my ZP48 selected to widescreen permanently and therefore it always stays in widescreen no matter what source (Ext) I select - I have a Freeview box which does the 4:3/16:9 aspect switching internally, connected to Ext1. Like you I have my component DVD connected to Ext4. Regards, yt.
  3. Ch3tan
    Ch3tan
    Oct 6, 2004
    289
    Croydon
    +23
    My TV switches to the picture mode that it is receiving. The option is automatic format in the menu. Sounds like your DVD is set to 4:3 or 4:3 letterbox. Set your DVD player to 16:9 from it's menu, and then see if it still happens.
  4. topmba
    topmba
    Feb 13, 2003
    249
    Bedfordshire
    +4
    Only SCART can change the viewing source automatically - it uses one of the 21-pins.
    As for the Auto format on the TV it is easely fooled by a white screen. Eg in Lord of the Rings it gets out of WIDE to 4:3 and again. Plus it does note recognise 14:9, as in Sky Travel or UK History.
