Tosh 32ZP18Q help needed please !!!
Discussion in 'General TV Discussions Forum' started by tobytyke, Dec 21, 2002.
  1. tobytyke
    tobytyke
    I've just purchased and installed a brand new Tosh 32ZP18Q TV and I'm well impressed with it.
    The only problem I've got is that I can't seem to configure my Tosh Sd220 DVD player to work with it. I'm using component video leads and an optical audio lead but when I set up the TV as per the manual all I get is very good sound but no picture.
    The DVD player was previously configured to work via SCART on the old TV.
    What have I missed ??? Any help gratefully received.
    :confused:
  2. groundy
    groundy
    Dec 8, 2001
    1,554
    39
    Northern Ireland
    Set the DVD player's video output to Video or S-Video. Hook it up via Component to the Tosh, select Ext 4 (I think :confused:, from memory as I used to have this TV) and you should now have a picture. The problem you're getting at the moment is that your DVD player is set up to RGB via Scart. To use Component, you need to shut off the Scart socket if you like by doing what I suggested above :).
  3. tobytyke
    tobytyke
    But I can't see the setup menus on the TV either. The only way I can get anything from the DVD (picture wise) on the TV is to use SCART again !
    :confused: :confused: !!!
  4. tobytyke
    tobytyke
    Thanks Groundy.
    I answered my own question. Used a SCART lead to configure the DVD player and it works a treat now.
  5. briandzo
    briandzo
    Dec 12, 2002
    373
    19
    Newbury , Berkshire
    can u tell me whether u noticed much difference
    from rgb scart to using the component i/ps.
    as i have this set and am considering buying
    a component dvd player soon
    thanks
    brian
  6. tobytyke
    tobytyke
    Hi Brian,
    I didn't really play with the DVD via SCART - just configured the thing to use RGB (component). I will say that the colour and picture quality via the DVD player is so much better than with the old TV (thru' a low-grade SCART cable). The sound aint bad either !
    Best of luck !
  7. bobbles
    bobbles
    I tried RGB scart and component with a tosh 210 and the same TV
    the component definitely edged the RGB scart
    Not as much as I was expecting
    However, using components does free up the RGB AV1 scart and if you are using another device with optical out to AV1 saves a lot of messing about
