Tosh 32ZP18P picture leaning to l/h/s
Discussion in 'General TV Discussions Forum' started by Doubledoom, Aug 26, 2001.
  1. Doubledoom
    Doubledoom
    Horizontal tilt can only be corrected in the hardware. There is no software fix.
    Vertical tilt can be fixed in the service menu under the TRAP setting.
    [ 26-08-2001: Message edited by: Doubledoom ]</p>
  2. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    844
    19
    leeds UK
    +15
    The standard resonse will be if the error is less than 5mm then the set is within spec.<br />There have been threads about sorting this out DIY, but it requires working on the live set moving coils slightly etc, definately not for the fainthearted with a new set!
  3. Steve P
    Steve P
    Hi<br />I've recently bought a 32ZP18P tele. Think it's great.<br />One slight problem though, the picture leans towards the r/h/s. <br />I know its been mentioned before.<br />Can it be corrected without the engineer coming out,if so how. Or is it not recommended?
    Could anybody out there help?
  4. Steve P
    Steve P
    Thanks for reply.
    I'll just have to ignore it.
