Tosh 32ZP18P colour staining
Discussion in 'General TV Discussions Forum' started by sc00by, Sep 30, 2001.
  1. sc00by
    sc00by
    Just recently had my TV delivered and am v happy with it.<br />However I've now noticed some colour staining and wonder if anyone else has this.
    On a white background:<br /> Right hand side of the screen shows a reddish/orange vertical stripe about 2 inches wide.
    Left hand side of the screen shows a blueish veritcal stripe again about 2 inches wide.
    On a black background:<br /> Seems to have a slight grey vertical line in the middle of the screen and either side is a different grey hue.
    I've seen these colour stains before due to magnetic interference and wonder if the TV has a degaussing facility.
    Can anyone else give this a go I know its difficult to get a completely dark screen or one with a white background but it would be usefull to know if its a common problem.
    Other than this ... I love this set.
    Ta
    Dave
  2. Doubledoom
    Doubledoom
    The tv degauses when you turn it off/on.
    However, the things you see don't sound quite right and i doubt it will be fixed with a degause
  3. se_warner
    se_warner
    Dec 6, 2000
    65
    Sandhurst, Berks,UK
    I have just received my 32" version of this set and have similar purity problems. I get a bluish tint on the lhs and other smearing in the middle. I ran the video essentials DVD and it looks pretty awful. I wll get an engineer out when I have time.
    One thing that have noticed is that the picture appears grainy via an aerial. The set was a replacement for a panny pg30 which had the shaddowy problems. On that tv the aerial pictures were superb, if I froze the picture you didn't see any graininess. Could this be connected with the purity problem or is this something else?
    Thanks<br />Steve
  4. Guest
    Steve
    I don't think you're going to get a good picture via the Ariel. It's something that's been mentioned from the very first post that I started way back when. The picture's superb through a digital feed but not through the tuner. Mine's watchable on all channels other than 5 but no where near as good as via NTL.
    [ 01-10-2001: Message edited by: OG ]</p>
