Tosh 32ZP18P buzzing me to distraction
Discussion in 'General TV Discussions Forum' started by bedazzled, Nov 2, 2001.
  1. bedazzled
    bedazzled
    I just got a Toshiba 32ZP18P and picture and sound are great but the set itself buzzes when in Cinema (zoom) view. The other views are pretty quiet but in Cinema the buzzing can be heard even when the audio volume is at normal levels. I've noticed it gets worse if you increase the vertical size of the picture in the menu screen. Should I get the set replaced or is this a characteristic of the TV (if so, it's very disappointing for the price!)....
  2. dts borg
    dts borg
    Sep 5, 2001
    578
    Hornchurch
    +8
    My old Tosh TV had this problem. The thing that scans the picture in the back of your set needs replacing.
    My new Tosh 36 zp18 makes a slight buzz at the moment, that I think will get louder in time.
    If your set is new ask for a replacement, as once the back has been opened the set will always be repaired.
    (you loose your right for a replacement.................:eek: )
    good luck
  3. Doubledoom
    Doubledoom
    Good job you don't need this view very often.
    Anyway, the problem is a faulty power supply. Fairly common problem so should be no issue getting it sorted under your warrenty.
