Tosh 32ZD26P problems/factory settings
Discussion in 'General TV Discussions Forum' started by overd0se, Mar 1, 2005.
  1. overd0se
    overd0se
    I`ve got some horrible overscan/geometric (the upper-left corner of the screen is pulled down-right) problems with the Toshiba 32zd26p in 480p mode. I thought it was an voltage problem, because the effect only appeared if white/bright pictures were displayed (white pictures need a higher voltage in order to maintain geometrics). So I tried some adjustments using service and design mode. After some tests, it was clear that it is NOT a voltage problem... reducing the values, making the picture more dark, did not have any effect. Unfortunately I forgot to record the default settings. I was able to reproduce them *quite* fine, but it would be great if anyone owning that TV could email or post me his/her default values of the design and service mode for comparison.
    best regards
