Tosh 32ZD26 and 32ZD26P ?
Discussion in 'General TV Discussions Forum' started by amancalledchip, Mar 27, 2003.
  1. amancalledchip
    amancalledchip
    HI
    Are these the same sets?Whats the P mean on the end?
    Thinking of getting one , just needed to know before i place the order
    Steve
  2. topmba
    topmba
    Feb 13, 2003
    249
    Bedfordshire
    +4
    P could denote a pan-european model as opposed to B for british. This should make no difference as it is multi-voltage and multi-tuner.
    Or it could be the model before Q as in ZP models.
  3. dgp
    dgp
    Mar 12, 2003
    11
    I'm told by Toshiba that both P and Q mean it is a pan-European and therefore multi-standard set. B is as you say British so will only work here in the UK.
  4. amancalledchip
    amancalledchip
    Thank - you
    Off to place order now.
    What HiFi rate it as set of the year.Just hope my one lives up to that.
  5. Gray
    Gray
    Dec 2, 2002
    17
    St. Helens
    I bought mine purely as a result of the article in what Hi-Fi (I only found this forum later) and I am made up with my TV.
    Just check Bilboos posts for the best settings and you should be well happy.
    Gray.
  6. amancalledchip
    amancalledchip
    Thanks Gray
    will check that post once set is up and running.Hope i am as happy with mine as you are.
    Chip
