Tosh 32WLT66 and Panasonic HT-530
Will4long
I just set-up my Toshiba 32WLT66 and my Panasonic HT530 Home cinema System, and both working fine, BUT,
How do i get the TV sound to use the cinema system speakers if possible.?
I have the Panny connected via component if this helps.
All help much appreciated.
scrapbook
Your TV has a red/white phono connector that is the audio out so you will need to connect this to similar 'in' connectors on your panasonic
Will4long
The Tosh wasnt as good as i expected it seems. Had to get a Scart to phono converter and put the scart end in the Tosh`s AV2 scart socket.
Working great now.
