Tosh (32) v Panny (85) - Remind me please
Discussion in 'Blu-ray & DVD Players & Recorders' started by timp, Dec 19, 2004.
  1. timp
    timp
    Jun 26, 2003
    71
    South Coast UK
    Can someone remind me of the pros / cons of the Tosh 32 and Pan 85. Prices are pretty close and having had an HS-2 (Panny) for a while I like the simple Partial Erase and Divide menu options amongst other things. Need help to choose one or the other.
    I realise this has come up a lot before but some of you lot are pretty good at picking out salient points!
  2. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +621
    XS32: Pros
    Can write to DVD-RW (as well as -RAM and -R).
    Has DV input
    XS32: Cons
    Has a steeper learning curve
    For the Pany 85 it is the opposite; e.g. no -RW, no DV, but easier to use.
    In terms of recording quality, both are excellent. Some reports say the Panasonic may have the edge, but I can't say for sure. I have the Toshiba and I find it excellent quality (and I watch it on a large 42" screen).
    I wanted DV in (so I considered the Pany 95 instead of the 85). I also wanted -RW, so I could make re-writable recordings to watch once (then reuse) on another player.
    Mark
  3. timp
    timp
    Jun 26, 2003
    71
    South Coast UK
    Thanks for that Mark - the DV in I already have on the HS-2, so no issue there. Not at all bothered about -RW as I'm more than happy with DVD-RAM. Looks like the Panny gets it as I'm already familiar with it's somewhat quirky interface (assuming it's pretty similar to the HS-2s)
    Cheers,
    Tim
