Tosb xs32 and NTL
Discussion in 'Cable TV & Virgin Media TV' started by lambchok, Nov 3, 2004.
  1. lambchok
    lambchok
    I have NTL connect to my Song TV with RGB scart. I am about to receive my new toy xs32 in the next few days :clap: Browsing through the online manual shows nothing about cable connection. Can I assume that it would be the same for sat. connection? Any suggestions to the setup? How do I connect my VCR to xs32? Much appreciated for any help.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    yes same as sat...does the XS32 have RGB inputs for recording via scart? if so use this and use the TV scart on box to XS32
  3. skyline32
    skyline32
    Aug 9, 2004
    75
    Connect the cable box to the AV2 port of the Tosh and the TV to the AV1 port. The RGB signal is looped through.
    There is a tiny bug, in that normally the widescreen pin is looped through but if you are in the process of doing a Rate Conversion dub, the widescreen pin signal output on AV1 mirrors that of the recording being dubbed, not the value on AV2.
  4. lambchok
    lambchok
    hi guys
    Just got the XS32. Problems already.
    Original set up of NTL (Surrey area) with Sony TV FX68 with 3 scarts
    digibox scart =>TV Av1 (RGB)
    digibox VCR => VCR AV2 VCR AV1 => TV AV3
    digibox RF out => VCR RF in VCR RF out => TV RF in
    No problem. VCR set up recognised all 5 terrestial channels and time set to BBC1 source.
    Now with the XS32
    digibox scart => xs32 AV2 xs32 AV1 => TV AV1 (RGB)
    digibox RF out => xs32 RF in xs32 RF out => VCR RF in VCR RF out => TV RF in
    Running the xs32 initial setup, AUTO time/date failed. AUTO channel also failed to pick up all the 5 channels. What's wrong with this?
    I would be grateful for any suggestion/comment.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    do you have an aerial or using cable for analogue 1-5?
  6. lambchok
    lambchok
    no aerial just the NTL cable analog 1-5
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    try a manual channel scan? otherwise is it working?
  8. tgs
    tgs
    Sep 13, 2004
    7
    Got mine yesterday. The autoscan failed to pick all the channels. So I had to manually scan, worked. The Auto time thing worked after I was tuned in :thumbsup:
    Now I figuring why the xs32 having trouble to read my MP3's on a DVD-R. I have an cheap Argos ALBA TV/DVD combo and that has not trouble in reading it. :mad:
  9. lambchok
    lambchok
    hi guys
    Have the rdxs32 over a week now. Very please with it. Steep learning curve and take time to figure things out. As for the setup, reconnect using the aerial which I stopped using since having ntl installed. Auto time/date is working now. Just burned a Datawrite Grey 8x DVD-R. It took 20 minutes. No problem but should it take that long? Burned a TDK DVD-RW 2x. Again OK. Tried Verbatim DVD-RW 4x. Failed to recognise. Message: Write protected. Unlock protection. Any suggestion how to unlock please.
  10. MikeHarrison
    MikeHarrison
    There is now a firmware upgrade available for the Red-Eye translator to enable the RD-XS32 to control Pace 10x0,2000,4000 and Telewest Cable STBs for automatic channel selection for timer recordings.Details here
