Torx screwdriver for N95.
Discussion in 'Mobile Phones Forum' started by tig, Jun 2, 2008.
  1. tig
    tig
    May 6, 2006
    298
    +17
    Anybody know where I can get a torx screwdriver for a N95 (I believe it's a T5.5)?
    I have a T5, too small, and a T6 which is too big.
  2. tig
    tig
    May 6, 2006
    298
    +17
    Anyone?
  3. ROBIN50N
    ROBIN50N
    Dec 15, 2007
    3,976
    +469
    ebay, most mobile fone stalls on markets have em.
  4. kiwinator
    kiwinator
    Aug 2, 2006
    122
    Norwich
    Maplins have loads of torx screwdrivers go there
  5. RobM
    RobM
    Dec 29, 2006
    13,226
    +2,168
    Seconded. They do a really nice little kit that has a variety of torx screwdrivers as well as a case opener and a couple of other bits. Served me well over the years ;)
  6. tig
    tig
    May 6, 2006
    298
    +17
    Thanks for the replies. I've already got a set from Maplins with a T5,6, and 7 but unfortunately the T6 is too big and the T5 is too small and has stripped the inside of the screw head.
    I've googled for a T5.5 which seems like it would be the size but can't find one anywhere so looks like I'm stuffed unless some one knows how to get these screws out when they've been stripped.
  7. vincie
    vincie
    Jun 23, 2007
    88
    +6
    Try Cromwell Tools, Google them and try the nearest branch to you. I'd be surprised if they couldn't source one for you unless they are especially made for Nokia.
    Vince
  8. tig
    tig
    May 6, 2006
    298
    +17
    Thanks Vince I'll give 'em a call tomorrow.
  9. samhain
    samhain
    Apr 1, 2004
    2,779
    South West Scotland
    +129
    whilst i remember where can you get replacement screws for phones, mine are a bit worn from screen replacements (Not N95 by the way)
  10. GSi-R
    GSi-R
    This place sells the T5.5 in this kit..
    MOD EDIT
    As to replacement screws, try member "nokiaparts" over on www.n95users.com/forum
