Torn between Samsung HD 850 and Toshiba SD 350
Discussion in 'Blu-ray & DVD Players & Recorders' started by indyjones, Sep 12, 2005.
  1. indyjones
    indyjones
    Mar 4, 2005
    47
    So there's 2 players costing about the same. Which one of the two would you recommend?
    Thanks, Indy :)
  2. loxster
    loxster
    Aug 19, 2005
    41
    mansfield
    hi indy!
    have just recieved my tosh 350 last week,do you want them for use with their hdmi? if so i know the tosh wasnt rated that highly for its performance using hdmi,they say its alot better through its component output than hdmi!
    i cant comment on samsung i havnt seen it in action!
    at the moment im in the process of wall mounting my pe50 plasma so ive only tried the tosh through scart into my exsisting crt, only annoying thing to report is the silly bright blue light on the draw front,its really bright and may cause distraction.
    performance through scart by the way is excellent so cant wait to step up to component!
    i paid 78pounds delivered(multi-region) from r.g.b!
    hope this helps.
