Eds1989
Hi there,
I have a small Topping PA3 desktop amp to power my Q Acoustics 3020 bookshelves.
I'd love to add a sub to this setup, but am not quite sure what my options are.
As the Topping only has speaker terminal outputs and no sub/pre-out, my understanding is I would need to find an active sub with high level inputs, and then probably speaker outputs that the 3020's would connect to?
I was looking at the Q Acoustics 3070s as it would fit my room and is reasonably priced. As this only has RCA inputs though, I don't think I could wire this into the speaker terminals on the Topping without risking damage?
In an ideal world I'd replace the amp for a 2.1 channel amp, but I can't find any that offer multiple audio inputs like the Topping has, which I'm making active use of at the moment.
Hoping someone can offer me some guidance on how to approach the sub, or alternative amps that would make life simpler?
EDIT: Perhaps something like the Wharfedale Diamond SW150 might be an option, fairly reasonably priced and has speaker level inputs?
Many thanks
Eds
Many thanks
Eds
