topline8 one for all web upgrading
Discussion in 'Home Cinema Control & Remote Controls' started by Duncan Harvey, Jan 8, 2003.
  1. Duncan Harvey
    Duncan Harvey
    Anyone had any luck upgrading topline 8 one for alls over the manufacturers website?
    I've followed the instructions, tried a variety of volume levels, but no joy.
    I'm holding the back of the remote against the speaker as recommended but no "complete" message is forthcoming.
    Will phone the manufacturers tomorrow but wondered if anyone else had actually got this to work
    thanks
    Duncan
  2. MonkeyDonkey
    MonkeyDonkey
    May 9, 2002
    401
    UK
    I managed it, after a few failed attempts.
    You need it pretty loud and make sure there's very little other noise going on around it.
    There's not a lot else I can say, just follow the instructions and it should work.
  3. jonny m
    jonny m
    Mar 22, 2002
    405
    Guys
    Easy way Ive found is to use a pair of headphones, with my ofa6 I just play the .wav file with the hole at the back pressed against the headphone - works every time and no waking the family up!
    Incidentally I found I couldnt get the upgrade to nokia ondig box 0751 +tivo 0722 to fit in the same memory in the remote - just because they lump lots of devices in the generic selections you can make on the internet. So I called the helpline and they just selected just the nokia+tivo and it worked fine.
    Also very impressed by quality of customer care line.
    John
  4. Adlopa
    Adlopa
    Nov 25, 2002
    74
    I just upgraded a 6-in-1 over the phone to cater for a TiVo and I must say that OFA CS is excellent.
