Topfield 5800 has hiccups
Discussion in 'Digital TV & Video Players & Recorders' started by drudge, Feb 2, 2014.
Tags:
  1. drudge
    drudge
    Aug 20, 2008
    11
    Hi. Our old Topfield 5800 has developed a fault on playback, where the sound signal is momentarily interrupted for a second or so, every one or two minutes. I think that at least sometimes the video signal is interrupted as well.
    Has anyone else experienced this problem, and/or have any advice about how to tackle it? Should I try reformatting the disk ? (Bit reluctant to do this, because of loads of recordings we haven't got around to watching yet !)
    Software version is TF NPT 5.13.65T. Device version is v5.3.36. Replaced the capacitors last year as a precaution.
    Thanks. (By the way, apols if this is in the wrong place--it's all changed since last time I visited . . .)
    Drudge
  2. Iken64
    Iken64
    May 5, 2012
    9
    Two things I can suggest:
    1. Set the video output to PAL (not Multi)
    2. Disable Interactive services
    You may have already done these, however...
    Regards
  3. drudge
    drudge
    Aug 20, 2008
    11
    Thanks very much for the quick reply. Video output was already on PAL, so I tried disabling Interactive Services. This may well have helped, because my impression is that that the interruptions may be a bit less frequent now--but unfortunately they're still happening.
    Does anyone have any other suggestions?
    Drudge
  4. Gavtech
    Gavtech
    Administrator
    Oct 25, 2005
    21,147
    +7,094
    ...and unpower the unit for an hour to clean out the memory buffers.
    Corruption lurking there can be a cause of this sort of problem.
  5. drudge
    drudge
    Aug 20, 2008
    11
    Hi Gavtech, and thanks for the suggestion--I like the idea of corruption lurking there . . . . still, it's everywhere else so why not ?!
    Wasn't able to try this for a few days but did so yesterday and alas there was no improvement. Has anyone got any other ideas?
    Drudge
  6. gazzzza
    gazzzza
    Dec 17, 2006
    295
    +12
    i would suggest trying here Toppy.org.uk ~ Index
    although this forums great, you wont get the specific expertise you can get from the topfield forum, there very helpful.
  7. drudge
    drudge
    Aug 20, 2008
    11
    Thanks, Gazzzza. Yes, I'm grateful for the advice received recently on this forum, but I had forgotten there was a whole set of dedicated Topfield forums over on the toppy site. Put it down to senility. I'll try posting over there, too.
    Drudge
  8. Jerrfn
    Jerrfn
    Feb 15, 2014
    7
    4
    Herefordshire
    My Topfield 5800 developed the hiccups. It would freeze or stop or at best stutter.
    Frequently aroudn 7.40pm! why?
    Then it was very bad... the solution, reformat the disk and then upgrade averything using Bobs Mystuff installer. It repairs and reinstalls the software. Sweet as a nut now! for a whiile.
