Top Spin 2 and 60hz problems
Discussion in 'Xbox Forums' started by texasboy, Dec 29, 2006.
  1. texasboy
    texasboy
    Sep 16, 2002
    390
    +15
    Can't get my head round this one.
    I got Top Spin 2 today for £15.00 but it won't work!
    When I insert the disc It says it's 60hz only and I keep getting a message to set my 360 to 60hz, only problem is it already is at 60hz.
    I've got it connected to my 506XDE via VGA and both the XBOX and 506 both say 60hz. I've tried multiple resolutions via VGA and 480p, 720p and 1080i via component.
    I've tried the composite connection as well but nothing.
    What I am doing wrong??
    I'm sure it's something simple but I need a second pair of eyes!
    Like a said above - the 506 states 60hz when I press the relevant input button and on the display settings on the 360 it says 1280x768 (or 720) and 60hz!
    All my others games work fine BTW.
    Any thoughts on this would be great.
    Ta :thumbsup:
  2. Indiana Jones
    Indiana Jones
    Nov 4, 2003
    37,007
    Bristol
    +9,718
    Always best to check the faq before posting mate as this is covered in there but basically you need to connect via composite, go into the settings, change it from PAL50hz to PAL60hz then connect back up using component and everything will be fine.
  3. texasboy
    texasboy
    Sep 16, 2002
    390
    +15
    Cheers,
    I had read the FAQ, I was of course, wearing my Ray Charles spec's!!
