Quantcast
Top soundcard for HTPC?
Looking to upgrade my ageing and frankly dissappointing SB Audigy in my HTPC.
Can somebody recommend me some great card in the £100-200 price range.
Also would appreciate any links to vendors of this cards.
Cheers,
Ant
gingercat
If the card is for a HTPC, surely you don't really need an expensive one - just one with an SP-DIF output - the card itself doesn't actually have to do much work.
CrispyXUK
I had a Revo 7.1 which was a good, now running an Audiophile 24/96 which is even better
C
Cameron
if you spend another £100 and go to £300 you can get a RME9632. To me it seems at lest as good as my DV88+ - though with some through testing I expect it will come out on top by a long way.
CaM
benje
audiotrak prodigy maybe? seems quite a big thing over at avsforum atm..
based on the envy ht24 chip - has coax in and out, 7.1 analogue connections, asio drivers and all for about £100 atm
alexs2
Have the Audiotrak prodigy 192 here.....I'm using it mainly as a good quality SP/DIF out,but it's sound quality isn't bad...not as good as a good external DAC though.....
In the upper price levels,the RME and the Lynx are highly recommended.
G
Gazebo2
Another vote for RME soundcards here if you want analogue outputs. If the 9632 is a little out of your price range at around £300-350, the older DIGI 96/8 PAD is available for just over £200 (less than £200 if you import from Germany)
I have experience of both cards and the sound difference is small - the quality of both cards is astonishing.
The only problem with the PAD is that the output is balanced (professional) so that you will need the advice of a competent hi-fi dealer to get a properly configured cable to connect to unbalanced (consumer) amplifiers. Otherwise look around for second hand DIGI 96/8 PST cards (with consumer unbalanced outputs). I picked one up for £100 a few weeks ago
:cool:
Thanks for all the suggestions folks!
After doing a little research, the RME 9632 seems like a very good card and I think its in my interests to wait a while longer and go for this card.
I do have a question though.
Does the 9632 have 5.1 analogue outputs, ie. the card will decode DD, DTS etc. I would prefer this solution as I'm wanting to make my HTPC into a pre/pro combination and do away with my Lexicon MC1.
Madders
I have used the RME Digi96/9 PAD but now use a Lynx Two B. With the new Lynx WDM drivers recently released I find the sound far superior in both S/PDIF and analogue configurations to the RME. Best of all, due to the $ exchange rate recently, I was able to buy from the US and have it Fed Ex'd to my door for less than £500!!
Cheers,
Steve
Similar threads
