Just a quick question regarding something that has bugging me. I always get top signal strength. But the signal quality is usually about 60%. Anyone got any ides? Thanks.
Incorrect LNB skew will do that.
As the picture is fine there's nothing to be concerned about - that's more important than some vague numbers, surely?The picture quality is fine. Could this be a problem in the future?
Check the signal on 999 and 515. They're on Eurobird, at much lower signal strength, and much more susceptible to skew problems. Skew adjustment is a fairly quick job.
I don't see what's likely to happen in the future to change things from the way they are now.
On what meter or receiver's meter & what dish
Meters on receivers can vary a lot - they are only a representation so you have to know the way a particular meter shows it as a level or use a pro meter which gives calibrated meter readings
However, a strong signal & low quality can be a local noise issue too such as a street lamp or telephone wires or pole in or near the dish or it's aim.
Cheers bud. The dish is in back garden. But not concerned at all because picture is fine.
