Top quality RCA leads
Discussion in 'Cables & Switches' started by sprint blue, Jun 5, 2005.
  1. sprint blue
    sprint blue
    May 20, 2005
    100
    I recently bought a TEAC Reference 300DAB mkII and excellent it is too. :thumbsup:
    The system was supplied with 3 double headed RCA to RCA leads, however, in the pursuit of excellence, I was wondering as to whether it is worth the bother of upgrading the aforementioned leads and if so can somebody recommend which type.
    The leads themselves are only short, probably 50cm at most.
    Thanks.
  2. Parklife
    Parklife
    Jun 9, 2004
    574
    28
    +33
    It is normally worth upgrading any standard leads. Some good choices are Mark Grant's cables (which he sells via the forums) or Van Damme.
