Top of the TV screen flicker badly with dreamcast PAL60 mode
Discussion in 'Nintendo Forums' started by junsuuk, Jan 1, 2005.
  1. junsuuk
    junsuuk
    Hi i own the LG Flatron 68cm TV and i get this annoying flicker when i choose the PAL60 mode with the dreamcast.
    The flicker happens to be at the top half of the screen mostly and there seem like some thicker colored interlaced lines more apparent..
    The color also flickers badly, especially red, blue and yellow..
    The TV is recent model and i tried with different cables (s-video and composite) on different AV inputs on my LG TV.
    I have also tested XBOX's PAL60 mode and GC's PAL60 mode they don't have the flickering problems..
    Has anyone seen problem like this? do you think my TV is not good or Dreamcast just don't like my LG TV?
  2. jelly
    jelly
    Oct 1, 2003
    1,294
    41
    nottingham
    +9
    dont lg make toasters???
  3. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,000
    48
    Reading, Berkshire
    +54
    Don't Sony make clock radios?
    I think the first port of call would be to try the DC on another TV Junsuuk, clearly you know your TV will accept SOME PAL60 signals.
  4. junsuuk
    junsuuk
    thanks for the reply, i tried on the other TVs they are all ok..
    i found out the problem, PAL60's red color was flickering.. when i set the TV to black n white then the TV dont flicker..
    i found out other TV's have bit of red flickering at the top of screen as well..
    its the LG tv that have more flicker than the others....
    XBOX and GameCube didnt have any problems on this TV and PS2's 60hz NTSC as well..
