lersince1991
- Joined
- Apr 12, 2007
- Messages
- 1,175
- Reaction score
- 16
- Points
- 328
Say if I was to buy the top end samsung 55D8000 which is 3d and runs at 800hz, what would people recommend getting with it?
I can get a 3D blu-ray Player with it for free, would I need the top end Monster HDMI cable to hook this up? monster states it can go up to like 600hz compatible cable or something.
Also what good would Monster's power centre's do? Surge protect, power filter, put sky coax cables through (just cut the line if theres a lighting strike or something?) and the green power feature turns the tv off when its left on standby and also does the same for the sky box and 3d blu-ray player. has anyone had any experience with this with a sky box say if the tis off but you scheduled the sky box to record a series?
And is there anything else i.e. decent satellite coax cable for sky?
Would really appreciate the help!
Cheers,
Luke.
Cheers,
Luke.
