Top Black bar = Reddish ???
Discussion in 'Plasma TVs' started by Stu Ward, Jul 11, 2005.
  1. Stu Ward
    Stu Ward
    Feb 22, 2005
    234
    Now then, i find this quite a weird one
    On certain scenes, the black bar across the top of my Plasma goes sortof reddish.
    I feel it could be a fairly crappy SCART lead going from my DVD player to SKY +. SKY then goes via scart to a Scart - Componant convertor to the panel
    If i swap the leads i get the same effect, but i would expect so
    Could anyone confirm my doubts ?
    Stu
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    8,767
    Norwich
    +646
    Sounds knackered.
    What screen is it?
    What happens when you put up a black screen? do it whilst the room is dark, it should look black, with no blue, green or red tinge to it at all.
  3. Stu Ward
    Stu Ward
    Feb 22, 2005
    234
    Black Screen, no signal = 100% Black Screen
    Screen is a brand New Panasonic TH-42PWD7BK
  4. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    Greyscale inaccurately set, black level incorrect? ISF calibration will put this right!
  5. Stu Ward
    Stu Ward
    Feb 22, 2005
    234
    Its funny cause if the screen is light at the top it tends to bleed into the black bars. If dark, then it looks perfect
    Stu
  6. Piers
    Piers
    Dec 11, 2002
    1,971
    Shropshire
    +227
    Still say greyscale is wrong.
  7. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Piers is right, I've seen this too. Mine used to do it with video upconversion, and I spent ages blaming the amp. The problem went away after using DVE to 'calibrate' but Piers will do a much better job than that.
  8. Gordon @ Convergent AV
    Jul 13, 2000
    13,999
    +2,803
    I'd look to see if any power saving options are on. If they are then that may cause the shift in black level and if greyscale is innacurate....which it will be.....you may see this issue.
    Gordon
  9. Stu Ward
    Stu Ward
    Feb 22, 2005
    234
    Whats DVE ?
  10. Gordon @ Convergent AV
    Jul 13, 2000
    13,999
    +2,803
    It's Digital Video Essentials. It's a set up DVD that you can buy from Piero Milani on this forum for around £10 and it'll help you get a better image on your plasma...
    You can also buy it elsewhere....from Amazon etc....but I'd recommend Piero.
    G
