Too much green
Discussion in 'Projectors, Screens & Video Processors' started by acita, Apr 27, 2005.
  1. acita
    acita
    Hello, i have a toshiba tlp-s30 the image projected has way too much green, i tryed already balance de colors from the menu, and at the very corners color is ok but the rest is too green is like a big green circle. What is going on how can i fix it? :lease:
  2. reevesy
    reevesy
    Feb 20, 2005
    4,941
    +1,136
    i had a similar problem with an themescene h30 and my denon via component
    (i'm assuming your set up is component right?)
    i did sort it out using the colour adjustments in both set up and advanced set up menues,just be aware that the adjustments i made had to be quite extreme and not just the odd bit of tweaking.
    you could try searching here and try and find another owner whos posted his settings www.avsforum.com
