Question Too much choice...
Ineedanewtv
Afternoon everyone,
I'm in the market for a new tv for the living room.
Primary uses: Xbox One X, Watching Football, Watching Movies (in that order)
Size: 50" or 55"
Room light: Can be pretty bright in there.
Viewing angle: Not dead center, We have a corner sofa, so someone is always off to the side a bit if we wall mount it, but also not too acute (not sure how to measure this properly).
Budget: £600
Any help appreciated!
Dodgexander
Hisense 55" U7A or if you want better HDR go for a refurb Sony 49" XF9005 from the Sony centre direct refurbished store.
You won't get good enough HDR for your One X buying new at £600.
Regarding viewing angles, you cannot get great ones unless you go for an OLED + get good HDR too. With LCDs you'll have to choose between good picture quality and narrower angles or worse picture quality overall and wider viewing angles.
Calculate what kind of viewing angle you need, if its more than 30 degrees from the centre of the TV you should go for a TV with an IPS panel and accept you are not going to get great HDR.
If its less than 30 degrees, my recommendations above and in the guide stand.
Which panel type should I choose for my TV?
My best value TVs, 2018-2019 Edition
