Too many wireless networks!
Discussion in 'Networking & NAS' started by scrapbook, Apr 30, 2005.
  1. scrapbook
    scrapbook
    Jan 12, 2002
    7,411
    +550
    I am currently sitting here in front of the TV and my computer is telling me there are 4 wireless networks to which I can connect!! Obviously mine is one so remaining 3 must be the neighbours!!
    Can I tell windows to ignore the other 3 and only pick mine up?? As soon as it detects other networks it temporary disconnects me from mine until i select the one i want for about the 5th time!!
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Not sure how common wifi configs are among the various suppliers, with my Netgear I right-click on the connection in the Network Connections applet and there's a Wireless Networks tab. On there I select 'mine' into the Preferred Networks list and it only connects to that one.
    It'd help if people knew how to secure their wifi lans by not broadcasting their SSIDs, if they did that your problem wouldn't occur. :(
  3. SeanT
    SeanT
    Jan 28, 2005
    6,163
    Coventry
    +368
    You just need to disable the ones that aren't yours in network properties afaik
  4. Desticado
    Desticado
    Oct 16, 2000
    1,477
    41
    Canterbury, Kent, UK
    +6
    go to your 'wirelees connection NIC' and select properties
    click on the 'wireless networks' tab
    click on the 'advanced' button at the bottom right
    remove the 'tick' form the 'automatically connect to non-prefered networks'.
    this will do EXACTLY what you want to achieve. Of course it assumes you're running XP SP2
    hopw that helps.
    Desticado (the IT Consultant) :D
