Too many TVs in 1 room - the remotes are not happy :(
Discussion in 'Home Cinema Buying & Building' started by shmee150, Jan 9, 2008.
  1. shmee150
    shmee150
    Jan 6, 2008
    38
    Ok this is something that has been really annoying me, but hopefully there is a solution that somebody will be able to point out.
    In 1 room, I have 3 televisions, all Samsung. The problem I have is that I want the remotes to be independent rather than how it is at the moment where 1 remote will control all 3. Say you want to change the source on 1 of them, that means going and doing it on the television otherwise you get in a mess with them all.
    So basically is there any way to program the television to a different code or something else you can think of??
    Thanks in advance!!
    Tim
