ok basically i have an old 720p panasonic plasma which only has vga and component inputs. I have recently bought a new graphics card for my pc which has dvi output.
So what do i do? i can buy either a dvi to component cable or a dvi to vga cable. which is best or are they both identical.
Ive heard vga gives u sharper crisper static image like when you want to surf and component gives you a better hd image for movies and less hassle with resolutions.
PLease HELP.
Thanks in advance
cheers
PLease HELP.
Thanks in advance
cheers
