Too good to be true? Tosh 32ZP18Q
Discussion in 'TVs' started by bobmccall, Apr 14, 2003.
  1. bobmccall
    bobmccall
    (delurk)
    I usually believe that if something looks too good to be true, it probably is.
    I've been in the market for a Tosh 32ZP18Q for a little while, today I've found one being offered (from Krish) for £999 including cabinet, speakers, delivery and interest free credit option. Its new, boxed, in stock and comes with a 1 year Tosh warrenty.
    Now that seems very cheap to me. Can it be due to the launch of the Picture Frame 2? Is it likely to be a grey import? Is there a 'usage timer' I should ask the shop to check? Should I snap it up or pay more from a 'known' dealer?
    Many Thanks.
  2. bash
    bash
    Nov 10, 2002
    2,381
    London
    +326
    personaly Id wait, Im sure it'll be cheaper still.
  3. Mick da Miller
    Mick da Miller
  4. Mo-S3
    Mo-S3
    Jan 24, 2003
    87
    cheshire
    Too good to be true ??? Nahhh gets even better !!
    I bought mine form John lewis's for £989 inc a 5 Year Warranty and free delivery !!
    Beat that !! :clap:
  5. bobmccall
    bobmccall
    Thanks guys. I've gone for it, couldn't wait any longer, should arrive on Thursday all being well.
    :smashin:
    Just one quick question (sorry if its been covered before); is a Component Video signal the same as an RGB signal? :confused: I am assuming it is. Will the component output of my Denon 3802 be a suitable input for the Tosh ZP18Q?
    Ta.
  6. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    Component Video is not the same as RGB. If you do a quick seacrh you will find a wealth of information. The Tosh TV has 3 Scarts, 1 of which will accept RGB. The Component Video Inputs are on EXT4 and are in the form of RCA Phono Sockets. You can indeed connect the Component Outs of your DENON 3802 to the Tosh if you are planning on using the Denon for video switching. Probably best to hook up the DVD player direct to the TV though, using either RGB Scart or Component if available :).
