too bright
Discussion in 'Nintendo Forums' started by dennis, May 28, 2004.
  1. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    i'm having terrible trouble with my gamecube,on most games the white is too bright,for instance i just started to play pokemon stadium for the first time,when you start in the desert on my tv the sand is glaring white and if you go to the map you cant read it,hard to explain but ive tried all the settings on tv nothing works,turning down all the settings makes no difference.i have the same probs on crystal chronicles,it's unplayable like this,seem to be mainly on jap games? :confused:
  2. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    surely someone can at least tell me if their game is the same,at the begining where you are in front of the train in the desert,the sand is glaring white instead of yellow,
    anyone :lease:
  3. dennis
    dennis
    Jul 2, 2003
    1,239
    surrey
    +54
    problem solved,courtesy of general panic.
