Tone Problems with Fronts/Centre
Discussion in 'Home Cinema Speakers' started by paulw77, Jan 19, 2001.
  1. paulw77
    paulw77
    Nov 18, 2000
    602
    28
    Wigan
    +48
    I have the following setup :
    Fronts : Eltax Symphony 8.2 floorstanders
    Centre : Eltax Symphony Centre
    Rears : Mission 760i
    Amp : Yamaha DSP-A5
    When I use the test tone to check my speaker levels, the tone travels from front left - centre - front right - rear right - rear left. When the tone reaches the centre, there is a slight increase in pitch when compared to the other 4 speakers.
    As the fronts/centre are from the same range, I would've thought that they would be well match tonally.
    Is there something I can do about this ? They are currently wired using different speaker cable, although I wouldn't think this would make a massive difference to tone/pitch.
