tone generator into small speaker
Discussion in 'General Tech & Gadget Forums' started by leecavturbo, Jan 11, 2012.
  1. leecavturbo
    leecavturbo
    Apr 24, 2009
    979
    28
    +26
    need to build a electronic circuit (555 ?) to make a speaker give out a constant 10 khz tone.
    tia
  2. GuitarGuy
    GuitarGuy
    Jun 2, 2011
    4,813
    Coventry
    +290
    I'll throw together a schematic for you tomorrow, as for actually making it, what do you plan on using? Pcb? Breadboard?
  3. leecavturbo
    leecavturbo
    Apr 24, 2009
    979
    28
    +26
    Just soldered in a mess hoping not many components
  4. GuitarGuy
    GuitarGuy
    Jun 2, 2011
    4,813
    Coventry
    +290
    That's possible but I wouldent reccommend it given you'd be using a 16 pin (if I remember correctly) IC? May be consider investing in a breadboard, they're great bits of kit and you can never use it too much, simple to use once you get the hang of it too.
  5. leecavturbo
    leecavturbo
    Apr 24, 2009
    979
    28
    +26
    Also need a relay with delayed momentary action.
    Was thinking 2 bog standard 555 timers?
    1 555 gives the action after time and the other 555 cuts the power to timer 1 just after the first timers time? will i be able to get accurate action between the 2? i.e 5secs timer 1. 6 secs timer 2?
    Separate project to 10khz
  6. leecavturbo
    leecavturbo
    Apr 24, 2009
    979
    28
    +26
    [​IMG]
  7. GuitarGuy
    GuitarGuy
    Jun 2, 2011
    4,813
    Coventry
    +290
    That looks about right bar one thing. The time constant (or delay) = Resistance x Capacitance, I don't see that anywhere :s
  8. leecavturbo
    leecavturbo
    Apr 24, 2009
    979
    28
    +26
    R1 and c1. ?
    Or do you mean the values?
  9. leecavturbo
    leecavturbo
    Apr 24, 2009
    979
    28
    +26
    Are there companies that will make a pcb ready for soldering in components?
    Can you get a chip with 2 555's in?
  10. GuitarGuy
    GuitarGuy
    Jun 2, 2011
    4,813
    Coventry
    +290
    Just spotted them, ignore what I said, god I hate being ill lol.
    As for pre made pcb's can't think of a company who make em unless you design it and send it to them, I still maintain that breadboard is the way to go. As for dual 555's on a single chip, google is your friend.
  11. leecavturbo
    leecavturbo
    Apr 24, 2009
    979
    28
    +26
    Thx esaglik.
    556 is an ic with 2 555 arrangements
  12. GuitarGuy
    GuitarGuy
    Jun 2, 2011
    4,813
    Coventry
    +290
    Rings a bell, there you go. :)
