Tonally Matching Ruark Speakers
Discussion in 'Home Cinema Speakers' started by aliT, Jan 13, 2001.
  1. aliT
    aliT
    Can anyone recommend / suggest a centre speaker to compliment my Raurk Swordsman II main speakers.
    Unfortunately I cannot afford the current Ruark offering. So I need to find a speaker that will match (as closely as possible) the Raurks tonally.
    I've had suggestions that the Mission 77C1 might be suitable, does anyone have any other suggestions. Budget is around £200
  2. Ewmacg
    Ewmacg
    Can't help you with the centre speaker I'm afraid, I am thinking about buying a 2nd hand pair of swordsman II's, how do you like them :)
  3. ufitsy
    ufitsy
    Aug 18, 2004
    3,257
    103
    Midlands
    +344
    AliT
    Have you thought of buying secondhand? quality centre speakers often come up on this forum (sometimes ruark)
    I advise you to search the "for sale" forum and post a thread in the "wanted" forum
    good luck.
