TomTom XL Europe - Mac Software Installation
Drunken Master
Established Member
Joined
May 12, 2001
Messages
837
Reaction score
7
Points
201
Age
48
Location
In the middle of a roundabout
I'm trying to install the software for my TomTom XL Europe onto my mac (OSX10.5) and the software just closes when I plug the device into the USB slot.
Any ideas??
can you download the software form there site .. just thinking it might be updated on there so it will work
I've found the TT Home software to always be a bit flaky - so make sure you have latest version from their site, not the install cd ...
can be easily confused with other usb devices plugged in so try and remove if you can ...
I'd plug TT in to mac, start TTHome and then switch TT on - this will at least allow it to recognise it's mounted after the home software loads ...
HTH
Jon
Lyngdorf MXA 8400 - Premium Power Amp Review Teaser #homecinema #poweramplifier #hometheater
Back
