TomTom Mobile 5 MMC and Map Questions
Discussion in 'Mobile Phones Forum' started by AVFan7667, Aug 30, 2005.
  1. AVFan7667
    AVFan7667
    Nov 29, 2004
    170
    16
    I am considering getting TTM5 for my Nokia 6680 to use mainly when travelling as I have factory-sat-nav in my car.
    However, I have a couple of questions I can't find the answer to anywhere.
    Can you get USA maps for TTM5, and if so where? This is where I would use it most.
    Can you install TTM5 onto a larger MMC card so I have space for other apps and images etc.?
  2. dejongj
    dejongj
    Sep 11, 2003
    28,065
    Beautiful South
    +4,492
    I don't think you can for the Symbian version. Expansys USA only sells it for the Smartphone...What you could do is download via plus specific city maps of the area you go are going to...Although this is not ideal and expensive....
    I've got TTM5 installed on my 512Mb DV-RSMMC, so there shouldn't be any problem with that one...
