TomTom for SE P1i??
Discussion in 'Mobile Phones Forum' started by history, Sep 4, 2007.
Tags:
  1. history
    history
    Nov 28, 2006
    61
    +3
    Is there anything available yet? Currently in the process of upgrading from N80 :boring:which has TomTom installed and fancy some thing completely different, being the SE P1i:thumbsup:.
    Just wanting to know if any sat nav apps available for it?
    thanks
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    what OS does it run? My P990i runs tomtom 6 even tho the tom tom site says no........ have a google and try some the unofficial SE websites/forums
  3. thefunkmiester
    thefunkmiester
    Jan 4, 2007
    152
    Hull
    I coudnt get tomtom5 or 6 to work on my P1i so plumped for wayfinder 7, 69£.
    Its a lot different from tomtom but I'm getting used to it....
    Apparently tomtom6 only works on s60 nokias, and the P1i works on UIQ3 IIRC.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    P990i runs UIQ3 i think so it should work but can be tricky
  5. apolloa
    apolloa
    Jul 9, 2004
    6,220
    +1,350
    I brought my P1i sim free and it's running the Irish CDA (Firmware) as their's no UK firmware yet.
    But I've had TomTom 6 running absolutely sweet as a nut since day 1. The bluetooth is fantastic with my GPS module and you can swap applications leaving TomTom running in the background fine. In fact, I really am amazed at the difference between the P1i and the P990i.
    The TomTom version I have is: 6.021 which as far as I know isn't the latest version.
    Hope this helps.
  6. thefunkmiester
    thefunkmiester
    Jan 4, 2007
    152
    Hull
    Thats weird cos when I tried installing 6.021, it stated "software not compatible". I wonder what I was doing wrong then...
  7. smokedog
    smokedog
    Aug 4, 2005
    3,046
    103
    +411
    I just tried TomTom Version 6.02 and it doesn't work, it installed it but wouldn't open the application.
  8. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
    what version are you using? (there are differnet version on the CD)
  9. apolloa
    apolloa
    Jul 9, 2004
    6,220
    +1,350
    I just coppied all my files across in file transfer mode onto the memory stick, then unplugged the phone and it asked to install the app, did so and it runs fine.
