tomtom compatable sd card
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by vaporand, Sep 13, 2007.
  1. vaporand
    vaporand
    Nov 27, 2005
    351
    Manchester
    +20
    anyone know what type of sdcard is needed, the size and price? looking for a 1or2 gig use in tomtom one v2 eu. thanks
  2. ram33
    ram33
    May 28, 2005
    1,150
    48
    +61
    any sd card should work - ive tried loads and not had a problem although ive only used up to 1gig
    i try to use the high speed type although im not sure it makes any difference
    plenty here:
    http://www.mobymemory.com/SD-memory.asp
