Tomtom 720 cant change country
EZDS
My Tomtom 720 is set on Tenereif, instructions say can be changed by tapping on the country flag in address but no country flag is pressent anyone know how to change to GB.
The Mincer
In the "Change Preferences" menu and "Manage Maps" try "Switch Map" and see what choices you have available.
A TT 720 would have been originally supplied with full Western European mapping. Tenerife would have been added as an additional map after purchase so hopefully Western Europe will still be installed in the internal memory.
To check what map version you are running now touch the satellite signal strength meter then touch the Version number and this will show you what software and map versions you are running.
EZDS
You got it in one thanks mate had downloaded latest maps but they werent on the Tomtom when I checked only the tenereif map was visible tho was showing as installed when I looked at contents through the computer connection. Anyway Thanks Again
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
